richard_2277
I have been thinking to do a mod on a guitar but wanted to hear from feeback from you all.
I have a nice Guild F50 jumbo that came equipmed with a Fishman Prefix Premium Blend pick up system (dual source: piezo and consensor mic...not the best there is but sounds pro enough).
Regardless of how & where I ever plugged in, I always first plugged into 2 separate countrymen 85 direct boxes so that i could feed channel strips a healthy balanced signal with no ground-noise or other. Also, those channel trips (could always offer phantom power to the DI boxes, so..no need for batteries).
In order to cut down on duffel-bag accessories & weight, I thought " why not acquire 2 countryman or jensen transformers (by themselves) and have them hard wired on the ends of each Fishman unbalanced source-wire. Then, modify my guitar to have 2 outs with balanced TRS wiring. This would give me a countryman/jensen transformer-quality balanced signal "right out of the box" (excuse the pun).
Then, when I plug into the two XLR pre-amps of my D-tar, I could utilize that Solstice's low Z preamps & have more headroom (and at the same time, juicing up the Fishman system's wimpy unbalanced outs).
I know there are better pick ups out there than the Fishman Premium blend (but this guitar already has the cut out and install). So, I am just trying to build off of what I have. And, with using Countrymans before (externally), the Fishman sounded better (than when stock unbalanced).
HERE IS ONE MODEL I WAS THINKING TO BUY: jensen-transformers.com/datashts/11p41.pdf
have any of you ever heard of a mod like this?
Jensen transformers can be had pretty cheap on ebay (new & used). Seems like it would be a pretty simple & lightweight mod to do (just soldier a few wires and ad some 2-sided foam tape).
please comment, everyone?
