Installing a drum kit into NI-Battery?
  • Thread starter Thread starter jkoenig
J
jkoenig
I just purchased Native Instruments Studio Drums, drum kit and I am having trouble installing it into NI-Battery. When I install it ,the file type of the samples changes to an itunes file type that NI-Battery will not recognize. Is there a way to prevent the samples from changing so Battery will recognize them? Better yet, how do I install the drum kit correctly? The directions generally stated that all I really needed to do is put the drum kit disk into the computer and follow the prompts. This does not work! Also, when I open NI-Battery up in sonar 4 the CPU (3.2 GHz P4) in my computer maxes out and often results in, "this program is not responding." I am not sure why it does this so if anyone else has encountered this problem and has found a solution please let me know. Thank You.
