After searching for this problem for two hours I could not find out why I cannot get this to work:
System:
Digi002/behringer ada8000
PT LE 7.4
mac os 10.4
I am trying to hook up outboard gear (reverb, comps, delay) to PT to use as an insert once in while instead of constant ITB plug ins. I would love to have a track going into the outboard unit and record the effect in PT on another track. For example, I have a simple delay unit's out going into channel one on the ADA8000 and the out on the ADA8000's channel one going into the delay unit (I tried this with other units as well). I can hear the unit when using an insert on ADAT1 (slight feedback from whatever unit is hooked up), but the audio is not going into the unit at all. I tried a few different configurations in PT (insert, send to adat 1, etc). What is the proper way to do this in PT 7.4?
System:
PT LE 7.4
mac os 10.4
