"Insert" connection question
  • Thread starter Thread starter Yasoo
Y
Yasoo
How does an "insert" connection work? I have a couple of these on my Lexicon Omega and I had them on my Tascam US-122. I was told they were for effects. How do the effects process the signal? I understand effects when they are in a signal loop, but I don't quite understand this insert concept.
Also, I accidentally plugged in a line-out on an amp into the insert (because I wasn't paying close attention oops). I didn't send a signal from the amp for very long, but is there a chance of damaging something with this type of improper connection?
You use an insert cable for them... It's a 1/4" Y cable. Plug the 1/4" balanced end into your insert... On the split end, the send goes into your processors input and the return goes into the processors output. Simple as that.
The insert is an "in/out" usually all in one 1/4" stereo (shield, pin and sleeve) type connector. These are used primarily to "insert" a processor like either a compressor or an external EQ. These are at line levl so an improper connection should not cause any damage to most equipment.
Thanks guys.
Lost studios, Office Space is a great movie. Chochky's 37 pieces of flair! Too funny. LOL!
I think I remeber a friend telling me that you can use an insert as a direct out if you plug in a cable half way. This might be true.
Inserts can indeed be used as a direct output. When utilized like this, the signal is BEFORE the EQ and fader section of the channel strip though so only the gain pot has any affect on the signal. In my opinion, this ain't a bad thing at all.
