Not sure if this is the best forum for this. Maybe a forum called 'Hooking It All Up' would be good
Could someone give me a brief rundown on the different levels put out and expected by gear in the recording chain (in general). For instance, I know that mic inputs (balanced) must go through the pre amp in my board, but does the un-balanced? On the board I have, I have an XLR input for mic, and a 1/4" labeled 'Line', though this must not expect the same voltage level as a 'line level', or I could plug my guitar directly into my recorder. But when I mix down, and plug the 'line outs' of my recorder into these 'Line' inputs on the board, it works fine.
I'ld look at the manuals, but I don't have any of them!
Does the internal circuits in the board run at the typical line level that the recorder does? This would suggest that Mics get pre amped a lot, guitars a little, and line in levels from the recorder none.
Also, do external pre amps boost the level to line level (of a typical recorder), or that of a guitar?
Ziller
Ziller
