I'm an idiot, why won't it play in Multitrack view
  • Thread starter Thread starter dialtone
D
dialtone
I press the space bar and also use the mouse to activate play, but nothing. It plays in the waveform view but not Multitrack. I tried restarting and opening a new session and coming back in case it was some random glitch, I also searched help and this forum for related issues but still nothing, What is it?
Look...I could be mis-interpreting the whole question/issue here, but at least check for the following.
ok......deep breath.....could be just a glitch....i don't know what you do, but anyways....
when u say "it plays on wave view but not on multi view", do you mean you can't hear 'it' on multi, or it won't play (scroll/run) on multi view.??
If it's the former, then you simply have a configuration issue, simple.
Goto options>settings>device preferences/order and pick YOUR master soundcard for your playback.
(ie. and example only)....put your 'master sound card' at the top of the 'playback' list....do the same for recording side..to be sure.
Go back to you multi view and ensure that number '1' is selected as your playback for all trax.
bam...u should hear 'it' now in multi view!.....er...um...I hope!
PS..your space bar will only work if you've actually activated that particular cool edit window. (maximised and active).
Regards.
It doesnt play as in, it doesnt scroll at all in Multi, I am thinking about reinstalling CEP. I have been having alot of issues with it crashing and so on,
Sure, reinstall it. That's a standard fix for when Cool doesn't work the way it should. It takes only a couple of minutes.
Cool, Ill do that tommorrow, now if I use my old waves that are saved in my documents in the new reinstalled CEP than I should be alrite correct? Are there any concerns with this?
dude...if you just explained that 'it' didn't actually scroll then I wouldn't have spent so much fucking time on this for you.....
Be more specific!!!...pleeeeeeeease!
Thankyou, :)
Spit.
