C
CMB Studios
If you track correctly, you should not need to EQ each track. EQ should only be needed to correct a particular singer's vocal 'issues'. I'll EQ my own voice to get rid of the boxiness (I'm nasal as all h3ll), or to add a little high end brightness - this is on the lead vocal though, never on the BU harmonies.
I put all the BU harmonies in a 'folder', so that I can then apply compression to that group of tracks as 1. I create a send from teh folder to the reverb buss.
I never EQ the folder, although I guess you could if you wanted a particular sound (lo-fi, telephone, etc).
I strongly disagree with this idea that if tracked correctly then you dont need EQ.
EQ sculpts the mix, as im sure you know mixing isnt about making everything sound their best and then mixing that together, its about compromise and gluing the parts together. If the backup vocals are EQ'd smiliarly to either the guitars, strings or lead vocals then they will sound muddy.. as we know mud and hiss come from overshared information space.
EQ isnt about making things sound better individually (sometimes it is) but its about making the mix fit together.
My technique is to usually roll off a decent amount of the bottom end and give a slight presence boost above or below the lead vocal (depending on if its a high harmony or low)
Usually compress each before sending to a bus aswell and then compress the bus slightly also.
And i usually always double/multi track all harmonies.
