I'm building a new PC (about time!). When I built my last one, there was much discussion about installing as "Standard PC" and disabling ACPI.
I'm wondering if that's still true or even necessary with all the improvements in the newer hardware.
Question #2. In my new case a standard IDE cable won't reach between the HDD and the CD drive. The overall length to the MOBO is fine. It's just the shorter section of the cable that's too short. Does anyone make IDE cables for drives that are physically far apart? What would happen if I turned a standard cable end for end, plugging the end intended for the MOBO into my HDD (40 pin 80 cond.) and the end intended for the HDD into the MOBO? That would reach, but will it work?
TIA
Twist
TIA
Twist
