kubeek
Because those cancel at wider part of the "center" than higher frequencies?
I can see what your saying, but here's a couple of sample numbers:Because those cancel at wider part of the "center" than higher frequencies?
1kHz equals ~13 inches full wavelength
2kHz = ~7 inches wavelength
5kHz - ~3 inches wavelength
Even if we assume that at least a 75% phase shift were required to have audible levels of attenuation, we're talking a "center" that's 3.25" wide at 1kHz, 1.75" wide at 2kHz, and .75" wide at 5kHz. All quite large enough to notice, though perhaps only on one ear at a time. Perhaps more important and evident would be that there will be just the opposite - coincident peak modes - just a half wavelength away for very definite apparent comb filtering at those frequencies.
I'm not saying that it wasn't a polarity issue, it apparently was. I'm just saying (I guess?) that we must have been given a incomplete description of the symptoms, because just a loss of bass wouldn't seem to indicate a polarity problem.
G.
60 volts peak into 4 ohm speakers is 450W (225W into 8ohm). Definitely not a home stereo.
The 9v battery, when you leave it connected for any longer than just sratching the terminals can produce cca 25W into 4ohm. That is more than enough to burn some voicecoils, because speakers are not designed for DC.
There is a big difference between rail voltage and possible swing of output.go look at some schemos of generic amps and get back to me... +/-60V is low for most amps...
The question I have is if it were a polarity reversal, why were only the bass frequencies affected?
G.
