I want to buy a professional booth...
  • Thread starter Thread starter Mr Music
M
Mr Music
Whisperrom booths is what im looking into
Need a booth to record clear, perfect while raw vocals...
equipment will be nice (no need to worry)
RnB to Hiphop to Alternative...
Mixing engineer available...Mastering contact available...Producer did most of the work...
The only problem is to record a perfect RAW acapella, without having echo, reverb, too much bass or just plain ol "youre recording in a room" type of recording....basicly pro recording....very good raw vocals...upfront and crisp....
maybe you want to recommend something else?
The room will get you sufficiently dead sound quality. The bigger problem is that the Whisperroom will get you a fair deal of isolation it will not get you the same isolation as double leaf stud walls. So if you got a lot of outside sound that you have to keep out (traffic, aircraft, etc.) you may need more
i have very little/no outside sound...
im only worried about its inside....
> Need a booth to record clear, perfect while raw vocals... <
You don't need an enclosed booth for that, and a booth might even add problems like mid-bass resonances. Since you don't care about isolation, all you really need is absorption on the walls in the area around the singers. I'm sure they'll also appreciate not being cooped up for long periods.
--Ethan
--Ethan
can you recommend a specific item?
