<BLOCKQUOTE><font size="1" face="Verdana, Arial">quote:</font><HR>Originally posted by UltraRecords:
I am wanting to build a studio in a 30' by 20' building.
My Equipment Budget is $20,000.00
The building is Done
If anyone would please give me a list of what items they would recommend so that I can make recordings that are pro quality as possible I would be very appreciative. ![Big Grin :D :D](/images/smilies/biggrin.gif)
<HR></BLOCKQUOTE>
I'll give you some advice based on some of my previous mistakes...
First. How many Channels do you need?
Do you need 16? well-GET 32!
Make sure that you can get in and out of your tracks without swapping cables. If you're swapping cables all the time-it's going to get really frustrating-I found this out the hard way!
Now, I'm saving up to get another mixer.
Figure out your format.
I chose
the Tascam DA-38's based on alot of research.
Even though Alesis ADAT has somewhat become the "standard format"-I still chose the Tascam format (Hi-8mm) because I put more faith in Tascam.
Recording on a PC? make sure that it is a DEDICATED PC!
Do not use your Recording PC for anything other than recording. No Modem, no Printing, No Gaming, no "NOTHING". This keeps you from getting "Internet-bourne-viruses" which can cause havoc on your system.
Mic's? I say get as many CONDENSER's as Possible.
Get a pair of D-112's or similar mic's for Kick drums, and a few good Dynamic Cardioids(Like SM57's, Beyer M422,etc.) for Variety.
Do not buy el Cheapo effects.
You're better off having a few quality effects than a ton of crap effects.
If you're going to wire it yourself. Work out a wiring Scheme ahead of time. Don't skimp on Cables-It's worth the extra money to buy quality cable.
Stay away from Multicore Snakes-when a Channel goes out,it can't be replaced...
Use 4" PVC pipe hung from the ceiling as a "conduit" to run your cables through. If you ever have to replace a cable-you can do it.
OR, build a "conduit" out of wood along the floor/wall base-boards with a "lid on Hinges" so that you can have your cables hidden, and protected.
Wire up a "Multi-output Box" and purchase 3 or 4 small mixers and let each musician mix their own headphone mix Also give THEM a cheap effect unit so they can put their own effects on their own Cue mix...
Tim
