I sound squeaky when I try to rap or sing
  • Thread starter Thread starter kratos
K
kratos
Whenever I try to record my self the result is always me sounding a bit squeaky ad childish.
I use an sm58 mainly because the area where I live has construction works going on.
How can I minimise the problem I hve?
you need to post a clip so we can hear what's going on.
No way to know if changing gear will help or if all the work needs to be done on your singing technique
A different mic wont change your voice.
As Clint Eastwood once said, "A man's got to know his limitations."
Some of us only do instrumentals for a reason....
Just to try to isolate some of the other things that could be giving it a squeaky sound if it isn't your voice, how far away from the mic are you standing? What is the mic plugged into? Are you running the mic through any hardware or software plugins? Was the mic ever dropped or did you buy it used?
If it's your voice you might want someone else to sing it. Believe me, I love to sing but can't.
For some reason, I just can't stop laughing at this even though it's not meant to be funny ! I'm not being cruel, it just tweaked my odd sense of humour.
All the while that I've recorded, I've made use of varispeed. Like, if I or whoever was singing couldn't reach some notes comfortably, I'd slow the recording down, sometimes as slow as three semitones {say, from C to A}. Of course when put back to normal speed, the vocal would sound half way to Mickey Mouse. Sometimes, by taking some treble {highs} off, that effect of a childlike voice or a high pitched Dylanesque whine can be muted somewhat. The other thing I used to do was double track, but one vocal would be done slowed down a semitone, while the other would be done sped up a semitone. When crunched together {with some EQ~ing and whatnot} it could be quite effective.
Of course, the way you mix your song and the way the instruments envelop the vocal can also have a bearing on whether you sound squeaky. But you may find that the voice you have is the voice you have and unless you disguise it by actually sounding unlike you, that's it. You're stuck with it so get used to it. You may not like it but everyone else might.
I guess the bigger question is: when you sing out loud (not into a microphone) does it sound squeaky to you? Does it sound squeaky to other people?
