ok now i need help on how to figure this math hahaha...sorry guys....but if i want to connect my large condensor mic with these specs:
Type: Condenser pressure gradient mic with large 20mm diaphragm
Frequency Range: 30Hz-20kHz
Polar Pattern: Cardioid
Sensitivity: 15mV/Pa
Impedance: 150W
S/N Ratio: 74dB (Ref. 1Pa A-weighted)
Equivalent Noise Level: 20dB (A weighted IEC 268-4)
Max SPL for 0.5% THD: 137dB
High Pass Filter 6dB/octave, 150HZ
Attenuator Switch 0/-10dB
to a preamp with these specs:
Input Connections XLR (balanced), ¼”TS
Output Connections XLR (balanced), ¼”TS
Input Impedance XLR, ¼” 2K ohms, 840k ohms
Output Impedance XLR, ¼” 600 ohms, 300ohms
Maximum Input Level, XLR +14dBu
Maximum Input Level, ¼” +22dBu
Maximum Output Level, XLR +28dBu
Maximum Output Level, ¼” +22dBu
CMRR >75dB (typical @ 1kHz)
Frequency Response 10Hz to 30kHz, +/-.5dB
Dynamic Range >100dB (20-20kHz) typical
Total Harmonic Distortion (THD) <0.1% (typical)
Maximum Gain
XLR to XLR 60dB (typical)
¼” to ¼” 44dB (typical)
XLR to ¼” 54dB (typical)
¼” to XLR 50dB (typical)
Equivalent Input Noise (EIN)
XLR to XLR -129dBu (A weighted)
¼” to ¼” -105dBu (A weighted)
Tube Type 12AX7A, Dual Triode, Hand Selected
how would i find the input gain to get it to +4dbu, then! to make sure ones its leaves my preamp amp.....how much outgain should i boost to make sure its hits my m-audio fastrack wich records at 24bits st the correct levels? i know thres some math involved which is what i would like some help on please.
Impedance: 150W
Maximum Gain
