M
		mikeh
I did a search, but did not find what I was looking for.
I'm looking for a very low cost ($200 - $300) resonator. For now. I just want to work on some accoustic blues/slide. If I get my chops together I can always upgrade - and if I don't use it that often - I don't want more than a couple hundred tied up.
I bought a banjo and later a violin on whims but I don't really use them that often - (for some reason I seem to think that I can teach myself how to play every instrument - how well is subject to debate) I suspect the resonator will also see limited use. There just ain't enough time to get good on every instrument (try as we may).
I will play finger style (no finger picks - some fingernail action) - in a style that is somewhat like Warren Hayes (although not nearly as fluid - at least not yet). I will likely use a glass, or plastic slide (maybe a steel - but they just seem tooo brash)
Any suggestions (Dean, Johnson, Epiphone, ???) - I'm not nearly ready for anything as expensive as a National. I want a round neck (to play like a guitar) vs. a square neck. Would you recommend all steel, or wood with a steel plate??? Specific model recommendations, would be much appreciated.
 ...needless to say it was full of water had probably been in the sea for some time as it was in bad shape the veneer was coming of the back the varnish had gone machine heads rusty etc a great split in the wood on the side, its worth mentioning at this point it is a spanish nylon strung...allthough my girlfriend said "your not taking that thing home are you" well i did dont ask why.
 !! Steel strings will screw up the neck but it was screwed anyway plus it wont matter as it would be a steel the frets would be just guidelines...well it works and it sounds way cool as these guitars are made to be as resonant as possoble for projection of the nylon strings, putting steel strings on really rings out I'd highly recomend trying this to start with allthough its doubtfull you'll find the guitar your after in the ocean
 hope this is helpfull Rapido.
