I have problems with my sound card
  • Thread starter Thread starter raywon
R
raywon
Studio 1784
Hi- I need help with my set-up, I am getting a lot of feedback on my vocals tracks noises, feed back and humming from mixer or external soundcard. I try turning down master volume in sound card of the pc its helps a little. I will appreciate if anyone can help me.
My current set up is as follows:
1. Compaq Presario SR-2100 PC – Window XP , Ram 3 gig, 4. Cakewalk Sonar Power Studio 250 with Sound Card
2. AKG Perception 200 condenser mic plug into- Mic Amp output from Mic Amp
In-put to Track 1 of Mackie DFX-6 channel mixer.
3. Mackie DFX-6 channel mixer- Main out-put (L/R) (2 Mic cables) connected to in-put mic 1Left and mic 2 Right of Sonar External USB Sound Card
4. Roland monitors- out-put (RCA Cord) plugged into Sonar External USB Sound Card
I welcome any advice thanks!!!!
Are you using any type of power conditioner? I ask because you didn't mention one in what you are running, if not you should. The ac voltage from the wires and radio freqs in the air all can produce a humming. Start with a good conditioner, and quality wires from mixer to soundcard and mics etc. Hope this helps
LOS
myspace.com/lostheone
Does your sound card have line inputs ?? If so use these and not the mic inputs on the sound card , the Mic inputs are for mics not the line level output from your mixer .....
Cheers
