rokinrandy
Banned Moderater
Somebody probably left a post like this one here for you already but I didn't read them all.. And you may know how to set up a bridge..but give this here a a shot..
This is the way I like to do my Floyd roses. Someone may disagree with me and want to talk shit and blah, blah ,blah .But Fuk'em......
I have zero trouble And it works....OK here it goes....
I Have 3 Floating floyds and I love them.. They are time consuming to properly set up, but worth the trouble...
I have the best results when I;
First after properly winding my strings at the machine heads I set my fine tuners in the middle for future play after lockdown!
One of the basic tricks is to Go back and forth with all the strings in repetition during tuning the instrument with the floating bridge...And you must do this while keeping the bridge level with the guitar body at the same time..
sometimes the springs need adjusting with a screw driver with even tension to level the bridge...
on my first tuning pass I atleast get it close to tune..on the first pass I just want the tension to hold the bridge level...But after that step is when i pass back and forth in repetition while tuning like this:
e,a,e,a,d,a,d,g,up to high e and back in the same manner to low e if needed and so on till it's right...
Now here is a trick that a lot of guitarist never do that helps greatly:
I always bend each string full or even more after getting it in tune before I move to the next one...And I do this until the string does not go out of tune anymore...Then i move to the next one...I go back and forth untill it's perfect.. And yes it takes patience..
I always double check to leave plenty of play in the fine tuner in both directions... And finally When all of this is accomplished the bridge is level and e.t.c.
I lock the locking nut....
If you are not doing it like this You will probably hate the Floyd rose floating Tremelo
My favorite is the old steinberger trems ... you just pop the string in and go with it..Drop down to all kinds of different tuning with a snap..and float like hell..
Heck what else is there for floating bridges,,,I thought floyd rose was it
They don't make the trans trem anymore..They don't make kahler anymore
Hope this helps you or somebody,RR
