Holy steaming piles of ***t Brad! I am NOT taking the rap for that lashup!
Yes, I said you could pinch a signal by crocking across a speaker but I also said you need a HIGH LEVEL DI and expected the croc leads would be PROPERLY wired into a jack plug! There are two dangers here..
1) You could short the organ power amp and that will be instant smoke since, obviously they don't intend people to connect to the speaker (would have fitted an Ext jack and so the PA likely has NO protection.
2) Although it is usually impossible to damage audio gear inputs with high levels, SPEAKER levels, 10s of volts CAN do it.
Another issue, do not disconnect the speaker. It is often said that transistor power amplifiers can work without a load. True in theory but I have known them to object and go instable then Pooof! If you want to silence that amp it can be done very safely with a load box. I can supply detailed drawings.
Mods. I will take a bit of flack for my original suggestion and will be VERY guarded in the future when suggesting 'creative' connection regimes!
