I don't get it...
  • Thread starter Thread starter marpstar
M
marpstar
If professionals record instruments track-by-track, then why do they need 48 channel mixers? If they only need like...10 or less to mic the drums? could someone explain this to me?
Well, an obvious answer is that they record a lot of tracks, "track by track." Indeed, there's probably a tendency to record more tracks when you go track by track -- doubling parts, keeping versions, recording solos and different sections on a different tracks, etc.
(Also, they don't always record track-by track.)
Even if you record track by track during production - requiring only a single channel - you're going to need separate channels to mix all the tracks together at mixdown......!
Just to amplify on Bruce's post, even if I use ten tracks to record drums, I'd use twelve at mix time as I usually set up a drum mix and then also assign some of the drums two a couple of bussus and send that to another compressor and bring that back to two more tracks. I also might use empty mixer channels as effects returns as they're a little more flexible than aux returns (EQ and such). It's easy to burn up a shit load of channels when mixing regardless of the track count.
Who would pay $80/hour for a studio with a dinky 16ch board? In addition to the other posts a pro studio has to be ready for many different situations.
They look cooler on the picture than 12...
Like memory, sex & beer, channel is sumthin we can never get enough. When you face multirouting mixing like Ted said, sometimes I even put some sub mixer in addition. Not to mention the busses, insert, monitor, send-return etc... etc...:eek:
