G
ggunn
Crystal Flavolian
Light said:Carbon resistors, including those in the track of a pot, are quite frequency specific.
Can you site a reference for this assertion?
ggunn said:Can you site a reference for this assertion?
I still can't tell if the capacitor bypass effects the tone when to volume is wide open or not. And am I to understand that as you turn the volume down it just compensates for the load change caused by the pot, but it still must lower the total volume right?dgatwood said:Uh... AFAIK, guitars all either use either an audio or linear taper pot. Both of those are dead shorts when turned all the way up.
Once you have appreciable voltage drop on the line, everything changes, though. Since you effectively have capacitance to ground by virtue of having a shielded cable, the result is that the resistance between the pickups and the output coupled with this capacitance turns into an RC low-pass filter.
mixsit said:Ok, still digesting. The link to Helmuth Lemme's article was very helpful (but it's only partly sunk in.
The spot about using a stepped tone control sounds like it could be a fun addition to explore, but first.![]()
Light, what is the nature of the downside to the tone you don't care for?
Wayne
Thanks again for responding. Hmm. Brighter I don't need.Light said:Yes, it effects the tone when the guitar is at full volume. It makes it a bit brighter, which I find unappealing. And yes, it still brings the volume down.
Light
"Cowards can never be moral."
M.K. Gandhi
Light said:...There isn't such a thing. You can do it with a tone control because you are just using one end of the track, but a volume control is a voltage divider, so you need both ends of the track.
Light said:Not one I can link to. Many times many books though. Not so much EE texts; after all, the kind of variability we are talking about here is not a consideration in any but a few instances. They just happen to be audio situations. None the less, it is an often and regularly observed issue in guitar amps, and to a lesser degree in guitars. Seeing as how you've admitted that there is some high end bleed on a volume pot (which is good as it is a well established phenomenon), to what would you ascribe it?
ggunn said:BTW, I am well aware of the approximations to reality that are encountered in course work; I am degreed in EE and I have been a practicing engineer for over 20 years. My specialty, however, is not in analog circuits.
cephus said:Well, practice makes perfect.
Practice asking for clarification without sounding like a douche.
