I ask the question because it seems that my 1202 VLZ Pro is the cause of a hum problem. Or the main contributor. I'm stumped as to how to fix this one.
Here's the skinny:
I hook up an EV RE20 mic via balanced XLR to the 1202. When I monitor the audio with AKG K240 headphones, I hear a low level hum in the signal.
I changed cables (several times, all were wired correctly), changed mics (an SM58 then an EV 635a), borrowed a DI box, and had no luck and no change in the hum with any of them.
So I removed all in's and out's save for the phones, then listened to channel one alone. At max trim and max gain, there's quite a bit of air, and a low hum deep in there. (Is this typical in the 1202, due to the mic pre I guess, and does anyone else get this?)
Inserting a mic cable into the 1202, but not connecting a mic to the other end, does not appear to alter anything that I can tell (if it does, it's too subtle for me to detect).
When I connect a mic to the other end of the cable the hum springs to life. If I drop the trim and gain to about 2/3 to 3/4 (roughly where they need to be to send a good signal to the Gina card in my computer) the hum remains just loud enough to be noticeable. Overall, the hum does not overpower the sound picked up by the mic, but it's always present, and noticeable especially between phrases.
The 1202 is about a year old, and little used (all of it here, never on the road). Could it be faulty, or normal, and is something else at work here? How can I eliminate this?
Thank you for your time and help,
kirkhere
Here's the skinny:
kirkhere
