A atibingler New member Oct 7, 2014 #1 Hey, just starting out with recording and am looking for a quick answer: Is this good sound treatment? What is bad, what is good, what can I do better etc. Sorry for noob question. Just a quick answer for quick question please!
mjbphotos Moderator Oct 7, 2014 #2 The best answer is 'try it and listen'. It may reduce some slapback echo from the room. It may just make it sound boxy.
R Rod Norman New member Oct 7, 2014 #3 I've certainly seen worse. Post an audio sample if you can. That's the best test. Rod Norman Engineer
S sheggs New member Oct 8, 2014 #4 Rod Norman said: I've certainly seen worse. Post an audio sample if you can. That's the best test. Rod Norman Engineer Click to expand... +1 - Otherwise you can run some tests on REW with the testing mic in the same position - Room EQ Wizard Tutorial - GIK Acoustics
