How to sample into Reason?
  • Thread starter Thread starter biz-tsar
B
biz-tsar
I'm not sure if my terminology is quite correct but what I am trying to do is take a guitar track that I recorded into Live!, and synth it in Reason. What I can't figure out is how to take my guitar track and I guess "sample?" it into Reason.
Thanks guys.
do you want to play the whole thing over your reason track, do you want to loop it, or do you want cut each note up and play it with a keyboard?
if you just want them to play at the same time you can rewire the two programs together - you open up a rewire track in Live and then open reason. reason's output will go to the track in live, and when you hit play in live, reason will play too. another option, that will use less processing power, is to render your guitar track as a wav file, then open it as a sample in reason's sampler and trigger the sample to start at the beggining of your reason track.
hope this helps - ill check back
