FALKEN
I think the title of this thread says it all....I've got a tom rim with some pitting on it...what is the best way to go about removing it?
 Pitting refers to small surface imperfections resulting from oxidation of the metal - small pits in the metal surface.foreverain4 said:what is "pitting"? sorry..
FALKEN said:are the pits supposed to turn black or does that just mean I need to scrub harder?
Ditto that. ^^^^^Atterion said:I doubt you can actually do much about the existing pits, but you can sand-blast the rims and then have them chromed or powder-coated.
You rang?orksnork said:beeblebrox
Zaphod B said:The black is probably the result of the oxidized material being spread around on the rim by the steel wool. Also the steel wool may itself be oxidized and depositing its crap all over the rim.
If I were you I would switch to a non-metallic media for buffing it. (Nylon pads are available in 00 and 000 at your local hardware store, paint department.)
At any rate, more elbow grease is required!
