scdaymon
Hi guys.
Once again, I really need your help.
I’m recording some stuff, and I definitely don’t get any problems while mixing clean and calm vocals (my own vocals).
(Usually a little reverb works just well, or, when I’m tired and don’t have the patience, I just fly for Ez Mix for some cool preset – Sorry, guess this is cheating!!!).
However, each time I try to mix screamed vocals (Note: not guttural vocals or death grunts and howls. Just screamed vocals… with anger and rage, but more or less clean!) I can’t get a decent sound.
It sounds empty, amateurish… without body, without impact.
Do you have any advice on this one?
At this time you know that sometimes I use EzMix (and probably most of you will not agree with this, ‘cause you don’t get to learn to mix .) However I can’t get this to work with EzMix.
By the way… I use REAPER (own an ALESIS io2 express, and a SHURE SM58).
Could any of you share some advices!
What effect’s should I apply on the track? Should I duplicate the track? Or maybe record again – the same words – and then overdub them?
Any cool vst’s for this?
Does the REAPER effects can handle the job.
Thanks in advance… any help will do.
