how to record a bass guitar
  • Thread starter Thread starter eskkes
why do you think i'm so f'n happy i found a use for it (the ball)
actually, it has worked on this chain also
jakson (strat copy)tube screamer-90's tube marshal (can never remember model numbers)-4X12 (newer) marshal cab-blue ball
just for certian parts though. most of git sound on that project are way different
but only really thoes two things and i've had it for like 2 years
(i've heard it works on kik but never tried it myselfe)
I used to DI, but it just always sounded like a very long, musical, fart to me. I have an active bass, does that matter? Since then, i've been micing my keyboard amp with an atm25 about a foot away, pointed at the center of the cone, mixed w/ a direct.
I usually DI bass. It's easier. :D
Depending on what I need in the song tho, it may be mic'd with a Beta 52, or DI'd, or both and then blend em.
Just my 2c
The controversial ART MP, previously mentioned, even had many sceptics addmitting its value as a bass direct--and it's true. The Avalon, I'm certain, kicks ass. But it's not 60 bucks. I think things lose points for not being 60 bucks. I personally wish everything was $60. I digress.
There are infinite solutions to recording anything. As far as bass goes, one simple and cheap one is recording direct with an ART. I swear to you, it works great.
The studio projects VTB-1 is even better and still cheap.
The Studio Projects VTB1 V series sucks eggs on bass IMO. The ART Tube MP StudioV3 is no Avalon U5... but the ART works ok as a bass DI (use the "FLAT" setting).
i mic and use d.i. on bass and blend to taste or just use the d.i.
I'm a bassist myself and I prefer the d.i., but I'll also mic the cab ,usually with an re-20, or a sennheiser 421.
(from a recent www.mojopie.com blog of mine, hope this adds something)
Some thoughts on bass track mixing:
Compression and limiting, done right can keep bass right where you want it. Dont just squash the bejeezus out of it...pump it in rhythm with the music with compression (pay attention to the attack and release times, have the release set to where it's pretty much all the way back up before the next beat) and set a threshold with a limiter.
This gives you a smaller dynamic range to work with, and an opportunity to make the bass track breathe and sound more alive at the same time.
EQ is your next best friend in line (EQ after compression is typically a better idea, you cut / boost frequencies before a compressor and the compressor is going to react more to that frequency that's been pushed out front and won't typically yield you the control you want) and you're probably going to want to bring out those wonderful mids you tracked (another key, when tracking bass be sure to have plenty of mids to work with later as they will define the bass...particularly at lower listening levels and on smaller speakers). Mix at very low levels while working with bass tracks, it will tell you a lot about what's actually going on and make it easier to put it in its space.
So controlling the dynamic range but not killing it, and using the compressor to actually add dynamics by adjusting the attack and release characteristics of the bass to flow with the timing / rhythm of the song. Then, setting a limiter where the bass won't jump out of place drastically and leave it's defined space. EQ to bring out frequencies that make the bass more audible "in" the mix. Monitoring at low levels will also be key at placing it as well.
War
eskkes said:
hi,
what is the best way to record a bass guitar?
any mic recommendations?
regards,
dave
To add, I read an article a while back where an engineer was saying the biggest mistake he made when tracking bass was to allow the bassist in the control room. The bassist was hearing himself (the click / attack mainly) blended with the monitor playback and wasn't digging in and getting the full sound he needed on the track.
So he put the bassist in a vocal booth with headphones, had him stand pretty still and mic'd the strings while he played. Of course he recorded it direct as well and blended the two.
I've never tried this but remember it being an interesting idea.
War
you can use a kick drum mic to mic the cab if you have the mic/good enough cab. It all depends on the tone you have. I've got good results double tracking, one direct out and one mic'd. I pick the best one for the track.
