Seafroggys
Being a drummer, for the past several years I've occasionally recorded videos of myself doing different drumming things. I mix the drums exactly as I typically do in a typical song setting, but things tend to sound a bit thin. Like, it pops out at you like I want it to in a song, but it doesn't really sound fat....doesn't fill up the space usually taken by other instruments.
I've tried adding reverb, doesn't really help. I just made a video today of a groove I couldn't play a month ago, did a little more buss compression than I might typically do, and I think it helps. What would you guys typically do if you were mixing a drum only track? I don't really just want to slam a hardcore compressor on everything to make it fat, but I'm leaning toward that route. Fortunately some of the stuff that Variety of Sound offers would work fairly well in this case (for the below track, I use Density Mk III for the overheads, and then the Thrillseeker VBL on the master, which is fast becoming one of my favorite plugs).
EDIT: Honestly wasn't sure if this should go into the drum forum, but I figured since this had nothing to do with drum gear itself and entirely with mixing I thought this was the more appropriate sub-forum. Mods, feel free to move if you deem it necessary.
