how to make "tracks"
  • Thread starter Thread starter jason2422
J
jason2422
i am using soundforge studio xp to record my sets and seeing as to how my sets range from 20 mins - 80 mins i will need to break them down and create tracks since there is no no actual break in the music. is tyhere a way to do this on soundforge? and if so how? i also have adaptec ez cd creator that i can use if needed
thanks
Yeah, you can select sections of the file and then save the selected part to its own file. Then you can work on the files individualy, fade them in at the beginning and out at the end or whatever.
You'll want to cut them into seperate files, then when you burn them, sure that you use Disc-At-Once instead of Track-At-Once, otherwise you'll have a 2 second gap between tracks. I'm assuming you're a DJ for some reason, and you want one continuous track, but logically separated.
Mo.
