ashcat_lt
I think that the idea of "mic technique" might be a little overrated. Not saying it's completely meaningless, but I don't think that it really has to be as dramatic a thing as many people seem to think. Most of the time it should really be subtle - a slight head turn or slight backward shifting. We're generally not talking about taking a step here.
There are some negatives to "mic technique". The most important in my mind is the tonality change that happens when the vocalist's face hole moves away from, or off-axis to, the microphone. Then of course any time you're moving you have the potential to make (unwanted) noise.
OTOH - purists will tell you that volume automation is the only way to deal with this problem, and they're not completely wrong. It is impossible to find a compressor setting that is perfect for the quiet sections and the louder sections. The two-stage compression thing helps. A multi-stage series/parrallel setup works better. At a certain point you've spent more time twiddling the knobs on all those compressors than you would have spent drawing in automation curves! And if you've got some sort of knob or fader to move then you can get some sense of the old "mixing as a performance" thing which I sort of miss but really completely don't. Once you get the wild mood swings under control with volume automation, it becomes much easier to find the compressor settings that enhance the track, rather than working so hard to correct it.
I personally haven't mixed anything where the vocals deserved that much attention in a little while...so I just slam them through a compressor.
