Hi all, this is pretty basic, but I've had trouble finding a how to on the web. Hoping somebody here had a pointer.
I've got a PA speaker (Sunn Model 2) in a 16ohm cabinet and one of the two 8 ohm speakers has died - killing the whole thing. Condition is fine - no visible damage. I'm hoping someone here can point me to somewhere that can help me troubleshoot what I need to check. (My mom was using it for square dancing classes and I wasn't there when it stopped working - don't know what happened).
When I put the multimeter on the terminals of one speaker it's fine - it comes in at 0.10 - so I'm guessing it's registering that one at 8ohm like it should be. When I put the multimeter probes on the terminals of the other speaker (the bad one I assume) I get nothing. It's like I haven't touched anything - infinite resistance essentially. I'm assuming this means wiring in the speaker is broken and signal can't get from one terminal to the other.
Is there a place I can go to learn what the "usual" suspects are to look for - especially if it's something I can try to fix myself before I just get another speaker? This is a very old cabinet - from at least the 80s, maybe earlier.
Appreciate suggestions. If "get a new speaker" is the best answer that's fine, but I figure there's probably some common things I can check first.
smili is online now Edit/Delete Message
