Massive Master
www.massivemastering.com
One left, one right.
Check the other thread you started...I gave you the solution for using heavy gauge wires with smaller/narrower terminals.
plus 14 gauge isn't that big.
plus 14 gauge isn't that big. I find it pretty hard to believe either set of posts won't take 14 gauge.
I'll be damned...but the 12 gauge speaker wire is way thicker in diameter!!!
Go figure.... *shrug*
The point is, are you actually unscrewing those connectors to get access to where you're supposed to put those wires -- Or are you trying to jam a 14ga wire into the banana connector?
man .... you're trying to stick a 1/4 inch plug into a bannana terminal .... the two are even faintly similar.I tried jamming a 1\4 TS Inch into it.
But, I went out and got some 16 gauge speaker wire that you can strip. Will this work?
