brassplyer
Subject line says it. How do you archive a track in Reaper?
Thanks
Thanks
Not a project a track. Cakewalk has the option to archive tracks so the system doesn't have to work playing tracks that aren't being used.There's no special need to archive a project. There are no proprietary file formats, except for the small .rpp file which is where all the program setting reside.
Make sure that when you save the project, you put all media files in the project folder, then just zip that folder and stick it away. Except for plug-ins, there's nothing special you need. All the audio files, the .rpp project file and if you use an IR files they should all be in the file folder. If you use an amp sim, or e-drums, then the data will be there, but the actual plug in itself won't be.
I don't even bother zipping the folders. I have a 4tb drive and just copy the folder from my computer to the external drive.
