I'm new to Cubase LE 4. So far, I'm noticing that it's not half as user-friendly as CakeWalk Sonar! I may wind up switching back. Anyway, my current question is:
How can I add a Reverb effect to just a little section of a loop? I don't want an entire track to be effected.
If you use the "cut" command (scissors on the tools bar) and cut out the section you need.
Right click on the track you have, and select 'duplicate'
This will create an identical track with the same 'cut out' loop section
delete the parts of the loop you don't need
without using the duplicate feature and using more tracks you can still cut out the audio part then "Process" it in place with whatever effect you desire
Without having Cubase on this computer, I think that you can automate the effect that you want. Get the effect to sound the way that you want it to and automate the amount of effect. I've never done it, but I believe that it's possible. Forgive me if I'm wrong.![]()
