Hi,
Thanks for your reply.
I have done what you've said before and it worked (definiation and cable connection are all okay). But let me re-phase my question.
To make it simple, I would like Sonar "sync" with key-press of the synth.
When I pressed the "Rec" button in Sonar, it will count 2 bars then I can play the key from Triton. But sometimes because of the bad timing (it is my problem), the first note will not record in the VERY beginning of the first measure. In other words, the note will be fallen in say : 1:00:xx. where xx > 1
So I would like to ask if Sonar has a feature (MIDI sync ?) :
1) Press the "Rec" button in Sonar then "Play" button. Sonar does not acutally start recording.
2) Play any note from Triton
3) Sonar receives the note from Triton (MIDI-Out -> In) then starts the acutal recording.
Is it possible ?
I remembered my old
Roland JV-1000 had similar features. It had a int. sequencer and it will not start recording until the first key pressed (key sync).
Hope you guys can have a better understanding of my question.
Regards!
Cowby
