Well... This is the basic dimensions of the room I'm working with:
The shaded walls are carpeted. The floor is hardwood and the wall nearest is plywood. There's windows on the end walls too. It's not a bad room I guess, but maybe it could have been treated more appropriately.
This is where I do all my work. I mix on headphones (I know...) they are Bose Triports.
I track into a Firepod/Cubase DAW(Windows)..
and for mics I have
2 mxl 603s, 2 mxl 990, 1 sm57, 1 audix i5, 1 beta 52a, and some CAD mics (the pro-
7 kit) for fillers. Mainly tom mics..
For the guitars.. I just ran a hot-rod MIM strat into a Marshall TSL 100, and the recording out from that into the firepod. Easy enough!
The drums.. I've got the 603s set up with one above the kit, pointed down at the snare, and one out in front about level with the toms, pointed toward the snare. The i5 on the snare top, 52a on the kick, two
cad TM211 for the mount toms, and the sm57 on the floor tom. I didn't use a room mic or hi-hat mic. My kit is a peavey radial pro 1000 w/ evans coated g1/hazy 300 snare, coated g2/clear g1 toms, and emad/eq3 kick with a towel in the bottom..
I'm still trying to figure out how to appropriately use compression.. but I just figured gating out not too long ago and it definitely makes things a LOT easier. Also I know I shouldn't have but I used compression to sort of makeshift "master" some of the tracks to get the volume up. Granite and Gold was the last mix I did. I think Nameless has real drums on it, but they might not be gated. The rest I believe are programmed drums..
Thanks for the input!
