wheelema
Boner-obo
Solo...
A bit of a follow up...
If you were to go with the Asus P5B-VM you wouldn't have to shell out for a video card. I have had very very good luck with integrated video. It is not the fastest, but then, that is not important to you. Note that you can always add on a video adapter if you wish.
You total cost here, wholesale, comes in at $855.58.
Luck
ASUS P5B-VM INTEL G965 CHIPSET SERIAL ATA300 MICRO ATX FORM FACTOR 1xPCI-E(X16)/1xPCI-E(X1)/2xPCI/4xDDR2 W/INTEGRATED VGA,SATA2 RAID,LAN(Gb),1394A,USB 2.0 & AUDIO (CPU TYPE:INTEL - SOCKET 775)
CORE 2 DUO E6300 1.86G (1066Mhz)
$313.78
CORSAIR VALUE SELECT VS1GB533D2 1GB (1024MB) PC24200 533MHZ CL4 240-PIN DDR2 DIMM
$130.10
COOLER MASTER CAC-T05-UW CENTURION 5 (SILVER/BLACK) MID TOWER NO POWER SUPPLY 5x5.25" 1x3.5" 4x3.5"(hidden) W/ FRONT I/O CONNECTOR, 80mm CASE FAN x 1 & 120mm CASE FAN includes COOLERMASTER RS450ACLX 450W POWER SUPPLY
$104.00
WD 160GB 1600JS SATA300 8MB 7200RPM (Bare drive)
$59.90 each or two for $119.80
LITE ON 16X SHM-165H6S BLACK OEM LIGHTSCRIBE DUAL DVD REWRITABLE DRIVE w/SW (White box)
$32.90
MS WIRELESS OPTICAL DESKTOP 3.0 PS2/USB KEYBOARD & MOUSE
$24.90
Luck
