How do you work Drumkit From Hell 2 from within FLStudio 6? Can you?
  • Thread starter Thread starter Spitz
Spitz
Well, the title says it all.
What's the best way to run DKFH2 from FLStudio 6?
Thanks a lot!
Spitz
Under the 'Channels' menu in FL there is an option to 'Add one'.
Add 'Fruity Wrapper' and click on the folder icon. This will drop a list of the VST plugins installed in your system, and if you've got DKFH installed correctly it will be listed here.
Check it, then double click to activate the channel.
Pick the drum sounds via the keyboard and fill in the tiles for the location of the drum hits.
Oh. Well, I got to that point, but I was hoping that there would be an easier way (like a better labeled way) of plotting each hit, as opposed to just picking the drumsounds from a keyboard.
Can I sort of break each drum sound off DKFH2 into a different channel (as in one for snare, one for kick..etc...)?
Thanks for your response man. I really appreciate it.
Spitz
Yes, but then you'd need to run one instance of the DKFH plugin for each drum.
Ok, that'd be impossible. One instance of DKFH takes most of my RAM as it is. :S
Thanks, though.
