Thanks
Thank you to all contributors!!!
Conclusion:-
There seem to be two main ideas....
One put the computer far away
Two modify the parts in the box
It is possible to extend all the cables, the keyboard and mouse being the easiest. They don't seem to suffer from signal loss over distance. The video signal does degrade but for my purpose am I bothered? Probably not. Access to the sound card could be a problem. Run long audio cables to your computer or use an external soundcard which then gives you a firewire run or usb.
If you are lucky enough to have a wall that you could drill through the cable extensions are not going to be very long!!! I am not so lucky! I have a bathroom one way and somebodies bedroom another!
Achieving a SILENT computer is very costly! Special components, special box, $3000 ish? Achieving a QUIET computer is easier ( replace power supply, use big heatsink on cpu, put the whole box in a packing case!!?? ) but if you're using a U87 what's the point? ( there may be a benefit here, long term hearing damage can be avoided!! Sitting next to a noisy box for years? )
The ITX box is a small project computer, the max cpu is around 500MHz without a fan. The power supply can be a laptop one again no noise. Not a great deal of money either up to now. You would have to have a hard drive (unless you booted over a network?). The ITX has one pci slot so you could install your soundcard. So the silent computer is possible for $200 ish? The only drawback being 500MHz limit. You may not be able to run Cubase but you could run Soundforge, capture your vocal or
acoustic guitar and then export the file to Cubase afterwards?
I am amazed that this has not been sorted out cheaply!!
( smartavi.com has an elegant solution enabling complete control over cat5 a 1000ft away.....but it's big bucks!!)
Thanks again to everyone who posted!
sixtiesman
