JLondon
Cat Herder
I didn't know I was going to run into so many issues when I started reading about how to go about this...
All I wanted to do was play a guitar/sing over a internet sourced streaming backing track and record it (for practice).
I learned so far:
1) Windows 7 removed the "stereo mix" (also known as wave out) as a recording option unless you have certain drivers (I finally got the right Realtek ones and enabled it)
2) Its easy to create a feedback loop or a crappy A/D converting situation.
3) It seems like the holy grail is to try and intercept the digital stream pre- A/D (before the line out)
4) Running the line out from the computer card into the mixer (or scarlett) is an option but not that great of quality?
5) Only the audio card in the computer will output a stereo mix stream from the computer? Why? Why can't the Scarlett do this?
6) Virtual sound cards are a thing for this. Haven't tried this yet.
7) If I try to hook up record and play paths through the Scarlett and back into the mixer I predictably get a echo/delay/feedback loop.
Whew! Is all this because the powers that be are afraid I am recording some copyrighted content? Why so hard?
My setup:
1) Yamaha MG82 mixer I bought for learning
2)Focusrite Scarlett 2i2
3) Reaper for a DAW
I am leaning on dumping the mixer and using an 4-8 input interface, seems easier, cleaner (I sometimes need 4 inputs). I finally got "stereo-mix" as an input option to show in my ASIO4ALL (changed drivers) but it has an error next to it (in use/MS synth?) and wont enable... GRRR All I want to do is record some Karaoke basically... I am pretty new at this so any info about how you are able to record computer (streaming) audio as a source in your DAW is appreciated.
I learned so far:
My setup:
3) Reaper for a DAW
