VSpaceBoy said:
"Its a Sledgehammer" ~ Pedro Sanchez
It's "-" not "~".
~ is not a dash it's a tilde. The tilde shouldn't be used in the place of a dash.
In languages, tilde is a diacritic mark (~) placed over a letter to indicate a change in pronunciation, such as nasalisation.
The tilde was originally used as a form of contraction in Latin documents. When an n or m followed a vowel, it was often omitted, and a tilde (i.e. a small n) was placed over the preceding vowel to indicate the loss of the nasal. This is the origin of the use of tilde to indicate nasalization.
In logic, it is used as one way of representing negation: thus ~ p means "it is not the case that p".
In electronics it can approximate the sine wave symbol (∿, U+223F), which is used in electronics to indicate alternating current, in place of +, −, or ⎓ for direct current. This most often appears on small transformers, which take household electrical current down to a low voltage suitable for small consumer electronics.
In punctuation it is sometimes used as punctuation between two numbers, to indicate that they are a range, rather than subtraction, or a hyphenated number (such as a part number or model number). Japanese and other Asian languages almost always use this convention, but it is often done for clarity in other languages as well. For example: 12~15 means "12 to 15", ~3 means "up to three" and 100~ means "100 and greater". In Japanese, the tilde is also used to separate a title and a subtitle in the same line.
In the MMORPG community, the tilde is used as an ending punctuation of a sort. It usually indicates bemusement.
The tilde is also used in instant messaging and other online chat communities, to indicate sarcasm.
In mathematics, the tilde, often pronounced "twiddle," is often used to denote an equivalence relation between two objects. Thus x ~ y means x "is equivalent to" y.
In English, it is often used to mean "approximately". Therefore, ~10 would be "about 10". Similar symbols are used in mathematics, such as in π ≈ 3.14, "π is about equal to 3.14". Since the double-tilde (≈) is not available from the keyboard, the tilde (~) became a substitute when typing. There is also a triple-tilde (≋), which is used to show congruence.
In Unix shells, the tilde indicates the current user's home directory (e.g., /home/username). When prepended to a particular username, it indicates that user's home directory (e.g., ~janedoe means /home/janedoe). When some Unix shell commands overwrite a file, they can be made to keep a backup by renaming the original file as filename~.
Used in URLs on the World Wide Web, it often denotes a personal website on a Unix-based server. For example,
http://www.widgets.com/~johndoe/ might be the personal web site of John Doe. This mimics the Unix shell usage of the tilde. However, when accessed from the web, file access is usually directed to a subdirectory in the user's home directory, such as /home/username/public_html or /home/username/www.
It is used in the Perl programming language as part of the pattern match operators for regular expressions:
* $a =~ /regex/ returns true if the variable is matched.
* $a !~ /regex/ returns false if the variable is matched.
The popularity of Perl's regular expression syntax has led to the use of these operators in other programming languages, such as Ruby.
In the C++ programming language, the tilde is used as the first character in a class's function name (where the rest of the name must be the same name as the class) to indicate a destructor - a special function which is called at the end of the object's life.
In the D programming language, the tilde is used as an array concatenation operator, as well as to indicate an object destructor.
The Emacs text editor forms the names used for backup files by appending a tilde to the original file name.
The tilde was part of Microsoft's name mangling scheme when it developed the VFAT filesystem. This upgrade introduced long filenames to Microsoft Windows, and permitted additional characters (such as the space) to be part of filenames, which were prohibited in previous versions. Programs written prior to this development could only access filenames in the so-called 8.3 format—the filenames consisted of a maximum of eight alphanumeric characters, followed by a period, followed by three more alphanumeric characters. In order to permit these legacy programs to access files in the VFAT filesystem, each file had to be given two names—one long, more descriptive one, and one that conformed to the 8.3 format. This was accomplished with a name-mangling scheme in which the first six characters of the filename are followed by a tilde and a digit. For example, "Program Files" becomes "PROGRA~1".
Computer programmers sometimes pronounce tilde either "squiggle" or "twiddle".
In dictionaries, both bilingual and monolingual, tilde is usually referred to as swung dash. It is often used to replace the headword of an entry when it occurs within the entry, in order to save space. For example, ~ing would represent singing at the entry for sing.
So you see you should have used a dash not a tilde.
Man, this BBS is full of dummies.
