T
twelves
How do I connect my Sound card to my Mixer Please help
http://www.rane.com/swf/sm82ch.swf
http://www.rane.com/sm82.html
Those are the links to my Mixer.
Im using Nuendo. and Echo Mia.
It used to work. Now after a Mobo upgrade it wont play sound.
Wave lab however still works.
I have several keyboards.
The instructions say:
MAIN OUTPUT jacks: These balanced Tip-Ring-Sleeve jacks are used to connect the main Outputs of the SM 82 to a
power amplifier or to additional signal processing. As is the standard with all Rane balanced outputs using ¼" TRS jacks,
the Tip is (+), the Ring is (–) and the Sleeve is ground.
So What outputs the signal to my ECHO MIA sound card?
Thanks! Im freaking out!
I had thought I could use the Effects Loop Send to output to my sound card Input but the instructions said this:
EFFECTS LOOP
The LOOP SENDS receive their audio from the Send bus
which is the sum of all Input program as determined by the
Input SEND controls. This Output may be used to drive
reverberation devices, flangers, phasers, etc. The output of the
effect device placed in this loop is returned to the SM 82
through the LOOP RETURNS. The level of the returned effect
is determined by the RETURN LEVEL control on the front
panel. The return section also provides a BALance control for
image placement.
EFFECTS LOOP
image placement.
