I have the VTB-1, and have changed the tube.
Not worth the effort - there are a bunch of screws to undo, knobs to pull off, potentiometer nuts and washers to undo, XLR in/out socket screws, 1/4" jack nuts and washers to place to one side, then fart about pulling out the PCB (because the tube is UNDERSIDE).
The tube effect is thrown in 'sidechain' to the main, solid state (SS), signal path, which always remains just that: SS.
If the signal path was tube all the way, then changing out the tube(s) may improve things, but in my experience, and I suspect yours will be also, swapping out the tube of a VTB-1 is just a waste of time.
I do like the VTB-1 though, as a good quiet preamp.
