How dirty cheap are you?
  • Thread starter Thread starter jake-owa
jake-owa
jake-owa
Banned
I'm the Mcguyver of cheap. If it can't be done with zip ties and duct tape I don't wanna do it!
I thought you losers :eek: might get a kick out of my new stereo mic stand. It will be fairly permanent so I don't care about having the mics stuck there. The mics are suprisingly adjustable and I can tilt, swivel and offset the mics for a few options.
Post some pics of money saving tricks you've utilized in your recording space. I would love to learn a few new ones for myself.
got no pic but il just explain it to you my cheap things. Im using a PC mic for recording. You know what PC mic looks like? white, small head, thin, and mostly very sensitive and can pick-up the most quiet sound in my room. to avoid recording unwanted noise, i take off the grill filter of a broken karaoke mic and put at the head of my PC mic and couples of tapes so it wont fall over.
ever seen one of these in a store?....my microphone stands consist of these without the pegs, and the microphone holder electrical taped to it.......
I prefer to call it "creative" not cheap!
I have saved thousands of dollars in my studio, by being "creative" or cheap as you may call it.
Here are some examples....
I re-used plywood and 2x4s from a former HO train layout to build walls.
Inside of an 18" thick wall I have several old mattresses and blankets.
I made guitar hangers for all my instruments from tool hooks from a hardware store.
I made all of my studio desks and racks from inexpensive pine boards, but stained a nice color.
I got used carpet from a friend when he replaced it.
I made my own keyboard and Midi racks with PVC pipe and spray painted them black.
I never throw anything away, and I often end up re-using stuff by modifing it to a new purpose.
Yeah I'm cheap....
Dom
:rolleyes:
Like some of you, I reuse a lot of material.
When I tore out my home studio recently, I saved every piece of wood that was longer than 2".
And, glad I did. When I had to put cross braces in between studs to box out outlets, switches and the like, one needs a few 15" long 2x4's. Scraps are good for this. Why waste a new 2x4 when you can use scraps?
The stringers in my studio, now that I've move them up and shorted them from 12' down to 58", required that I double them up for strength. I got several 58" stringers out of each 12' stringer as I tore them down, one at a time.
Electrical wiring, well, I've reused a lot of the old stuff. Same for outlets, wire nuts, etc. I'll be buying new outlet covers and switch plates because instead of cheap plastic, I want brass. No big deal.
I've attached a picture of my old studio racks, before the tear out. There were four or five of these, I simply made properly sized 2x4 verticals, then attached rack rails to them. Instead of buying rack rails from a music store, I simply took a 7' high aluminum relay rack and cut it into 18U and 6U sections. 6U on top, 18U on bottom, so I could put a small cross brace between.
The rack rails, before mounting, are then cut lengthwise on my table saw, because then I get two rails for the price of one :) There were threaded holes on both sides of the u-channel rails. Why not use both sides? this way, a 42U rack can be cut up to provide 84U of space!
This is just SOME of the cheapo stuff I've done here at home. Pro studio to follow...
Oh, one more thing, I buy 99% of my gear on e-bay now. I've ended up standardizing on equipment thats not exactly the latest and greatest, so e-bay is a good source for this stuff. Instead of repairing stuff, I actually have a small stockpile of "extra" TMD1000 tascam digital mixers because it was less costly. Same for the akai recorders. Spare boards too.
Thinking I'm clever, I took the proms out of one of my Akai DR16, 16 ch hard disk recorders and put them into one of my Akai DR8, 8 ch hard disk recorders. Magically it boot up, and thought it was an akai DR16. 16 channels for free! See, the internals/processing part are identical, the difference between the units is the amount of A/D and D/A it has, as well as very minor changes on the faceplate. But the display, the processor, the amount of memory, are all identical. The motherboards inside even have the same part number.
To solve the "I'm now a 16ch recorder but only have 8 inputs" problem, I shoved in a 16-ch adat card (which is the standard in my studio), so the DR8's are now full-fledged 16 channel recorders. All at the cost of moving prom chips. Since I can copy prom chips with this little thing I have, I took the latest version of the OS from one of the DR16's and made enough pairs of proms for each of the four machines that didn't have that version. So now I have five DR16 recorders :) Two look funny heh-heh
Pro studio -
I had two over the years, the first one went under because I spent more than I should have on equipment, and couldn't recoup. I wasn't the most financially responsible 23 y/o there was.
Anyway, the second pro studio I had was with a partner, who expemplified the stereotype of his last name (......witz), and I have to say we made a good pair, being partners. We're still good friends today.
We had a barcode cataloging system so all the tapes were stored in a media vault, and numbered with a six digit barcode. We did this because we were afraid of artists breaking in at night, and stealing their master, because we wouldn't give masters out until full payment was rendered. Not that it ever happened, it didn't.
But anyway, when the tapes aged to the point where we really shouldn't reuse them anymore, Harry would actually spend his time peeling off the inventory barcodes, so they could be scoth taped to the new reel.
The folks using the practice rooms were very hard on mic cables and patch cords, Harry and I spent a lot of late nights resoldering ends. Nowadays this stuff is cheap enough to just toss it into a box and buy new.
Harry would also dilute the windex for the front windows to the lobby. I do enjoy making fun of him, as he does me.
Whenever we upgraded or added to the gear, we always went together. It would literally take us four hours to buy anything. He'd torture me on price "That used Poly 800 is just as good as that PF85, lets get the Korg)" and I'd torture back "Lets get this midified Hammon B3 instead". The one music store we shopped at got to know us very well, *I* was the guy to sell the equipment to, and *Harry* was the one they had to negotiate with. Harry always got the price way down off the sticker price through research, bringing in ads, as well as free patch cords and power supplies and other trinkets. Me, I'd have paid "store price" (you know, that really kind 4% discount!) and been happy to go home. Harry taught me a lot, I have to admit.
I could sooooooooo go on, but it will get boring for ya all at some point.
What I always found amusing, is Harry's ability and willingness to torture music stores on price, but if any hagglers came into our studio (mostly high school aged garage bands), he'd throw them out faster than they walked in. :-D
I guess I'm not quite that cheap when it comes to my gear. I'll gladly blow my hard earned money on music stuff.
But don't ask me to spend my gear money on crap like new bed sheets or dishes. I'm 31 and I've probably never spent more than $40 on anything that didn't use electricity or hold up something that used electricity.
But don't ask me to spend my gear money on crap like new bed sheets or dishes. I'm 31 and I've probably never spent more than $40 on anything that didn't use electricity or hold up something that used electricity. [/B]
Same here.
Thats what my wife is for. She has no problem dropping $150 on bedsheets. Though 600 count is niiiiiiiiiiiiiiiiiiiiiice.
If its not cheap, I dont do it.
-built a rack for compressors out of 2x4s with sheetrock screws
-built our own speaker cabinets for playing live with the band
-wired many xlr cables with left-over cable from a job
-made drum pallet from carpet found by the road
-made stage from cynder blocks and 3/4" plywood
-made boom stand with two straight stands and a brick for a base
-used guitar cables as patch cables
-used a pair of #12 copper wires for speaker feeds
-duct tape is used for
cable binding
mic holder
holding the grate on the front of amps
marking the mixer channels, mics, and mic cables
repair broken antennas on wireless mics
replacing missing battery covers
as a gromet for anything metal
Student-Cheap
Hey guys, thought the cheapo thread was pretty cool. definitly where i'm at. I'm 17 and in highschool. i mostly record myself and bands i find out about at school.
A few of my cheap accomplishments:
Very nice computer desk, full-back chair, laser printer, 17" monitor, and laptop just powerful enough for stereo field recording...all salvaged from Siemens (huge companies waste everything) basically they needed minor repairs and the company didn't want to deal so my dad brought them home for me to fix and use. Using the laptop, i recorded a bunch of bands at a local "battle of the bands" type deal. sold a cd of their performance to each band for $25....by the end of the day i was able to go buy a multichannel soundcard for my main recording computer and finally burn my SBLive! card.
My new secondary desk is an old desktop (from siemens of course) sitting on top of plastic bins from walmart (also good for storage) and then for a second-tier to hold my ghetto ass DW-6000 keyboard i used cylider blocks with some shelving i had lyring around
oh, and of course a little pirated software never hurt a poor student trying to learn
My wife keeps calling the studio "Trash picked sound" because of all the stuff I (and she!) have hauled home from the curb & dumpsters.
Doors, office partitions (as gobos), guitar amps, wood etc..
She grabbed a couple of teak chairs a guy who was moving had put out for pick up, re-covered the seats and they are like new :)
Still looking for that Neve Console though :)
Kevin.
"The Dump" here.
I picked up off the street a projection TV a week or two ago. Was a good 200lbs plus. Managed to get it into the truck, home, and into the driveway. I plugged it in, and the tuner is dead. The A/V jacks worked, so I was going to hump it into the living room, and attach the digital cable box on the A/V jacks, and use it that way.
Make sense?
Yesterday was trash day, and seemingly a certain wife dragged this thing from under the garage eave out to the street early morning.
*sigh*
My wife hates my truck. I do so much "casual" garbage picking its not funny. In fact, a lot of the studs in my studio at the moment were trash plucks. Had to cut them down a bit, but hey, wood is wood.
Oh well, win some, lose some.
If I drove by an API sitting by the curb, you'd hear the screams from here to wherever you happen to be.
Those screams would be from the process of me using zip ties and duct tape on you for trying to take it ;) Muhah hah hahh!
Actually Id help lift it after shooting my colon across the 48th Parallel. Dang those buggers are heavy. I've worked on API's but I don't have the room for one, maybe a smaller Neve if youhapen to find one by the curb :)
SoMm
SoMm
They are big!
If anyone finds one of these in the trash, call me, I'll be right over :)
This is my current fantasy console. I'd sell my wife to get one of these, and I'm quite fond of her :D
ok, I have to jump in on this one...
Being that were on the Studio Building and Display Forum this is a good place to let out some great secrets (I'm a closet dumpster diver ..LOL). About a year or so ago I started to redo my shed into a recording studio. I was driving home form work and noticed a garbage truck outside the local Home Depot., I could see a nice piece of rigid 702 with the upper corner broken off being covered up ...and wallah, I've been a home depot dumpster diver ever since. DAMN, they throw away alot of good stuff. I started going to all the other home improvement stores and found out when they haul their trash. Here's a list of stuff I gotten for the studio so far--
Ripped piece of pond liner, the same stuff I had already purchased for sound proofing.
Lots of split or bowed 2x4's (most of it usable)
3 light track light, was bend up a bit, but looks great now
a NICE split piece of oak, I built a control rack out of (like $50 dollars worth)
Some insulation, (hopefully I'll find some more)
dewalt 18 Volt battery (now I have two for my drill set)
a masonry blade
lots of Nails and screws
oh ya and a solid wood door (sanded the hell out of it)
Lots of other stuff. Ill admit It's been kind of time consuming, and some of its crap, but hey you never know when your gunna need more crap! He HE and I have fun doing it. :)
Now if they would only throw away a good amount of some half inch sheet rock ...might have to buy that one.
Anyone else a packrat? I have saved little pieces of wire and crap I find on the job sites I am on. I have saved shielded wire for the purpose of wiring mic cables, but never get around to it. In my closet I have....
a broken 4 channel mixing console
4000 feet of small pieces of wire
2- 12" speakers that are busted
1- 4" tweeter (busted also)
several pieces of rack track that are smaller than 2" cut
broken mic clips
a reel to reel machine
guitar cords that have been raided for the connectors
broken straight mic stands
screws that someone threw in the trash
600' coax cable
a guitar with a broken neck
a guitar with no guts
dual well casette recorder (one side dosnt work)
3 pair of broken headphones
