how can i tell if it's the mic?
  • Thread starter Thread starter jugalo180
jugalo180
jugalo180
www.moneyistherecipe.com
how can i tell if the mic is a piece of crap? i have a 50 dollar radio shack mic that i use for vocals, and it sounds okay, then again i don't even use a sound proof booth just headphones and a quiet room. any noise is reduced and cut out in acid pro. my only concern here is the quality of the vocals. they sound good to me but with a better mic am i to expect a lot more or can i just stick with what i have and just eq and reverb my vocals a little to get what i am looking for?
me again
i have this microphone modeler plugin for cubase and i was wondering what is anyone's take on it? is it worth the money? can it step my radio shack mic up a notch? if not, then what is the best vocal mic i can get at an inexpensive price. if you have any ideas can you let me know the manufacturer of it or either the web address. thanx in advance
borrow some more expensive mics and try them out. then you be the judge if the extra expense is worth it on your voice.
I Agree...
I agree with LittleDog... If the Radio Shack Mic is fitting your needs, and you're happy with the sound you're getting, I wouldn't be too upset at continuing to use it...
You need to ask YOURSELF - Is my vocal the way I want it? Does it sit in the mix like I'd like it to be... If not, then maybe a different mic or some other adjustments would help it work - Or maybe you need to look at a new mic...
When I first started - I used an old EV PL25 or something like that... I thought is sounded great and someone told me to go get an SM58 and that would "Solve it all"... Well, it didn't - I still used the PL for quite some time...
A few good low cost mics that I use are: Rode NT1, SM57, SM58, Rode NT3...
Maybe try going to a low cost condenser mic... Those may boost your signal and give you a little more control over your recordings...
Here's a good example - You're using your RS mic for recording one day and you get some good vocals but you need to finish up the next day. The following day you re-record some parts and finish the recording... Upon playback of some of those vocals you find that they "sound different" than the ones recorded the day earlier. It could be because when you recorded you were standing six inches closer the day before or perhaps you were at a different angle...
Buying a more expensive mic generally means that this kind of little detail / change is erased... I've found that with the NT1 I can have my clients stand at any position with 24 inches of the mic - on the side - standing direct, etc. the the "tone" of the vocal will be the same...
I've read a number of books and experimented with lots of stuff and have come to the realization that: "More expensive gear only means that you can make more mistakes in your technique when recording or mixing..." (remember this is a "general" statement) ie: because the mixer has such great signal to noise ratio, you can leave a few sliders up. Or your vocal is not placed "exactly" at 6" from the mic but the mic picks up good enough to compensate for that.... That's what professional gear will do for you...
Bottom Line:
Use your ears and if you like what you hear, continue using it...
If it's giving you trouble or there's a detail you don't like? Get rid of it! ;)
Riverdog
www.homepage.mac.com/riverdog
thanx
thanx dude that cleared up a lot of future questions that i had in mind
You Bet!
One last point...
Along the "Pro / non-Pro" gear...
I've heard a lot of great music made with very little...
Don't worry about if other people think you're a professional because of what you use...
What you do with it is the key...
Using that RS mic to the best of its ability can yield the results you're looking for...
(ok I'll get off my soapbox!)
Good luck to you!
Riverdog
thanx
very good sermon river dog, words of wisdom indeed.
