The following is some info on Copying + Inserting for the BR-8.
If you want to copy + Insert a entire track to a open track:
Utility.
Track.
Copy+Insert. Select Track source and Destination.
Then click LOC (Location)
Then select "ALL".
Then select "GO"
Here is How I do the "Copy + Insert" for a partial part of a track to a open track.
Utility.
Track.
Copy+Insert. Select track source and destination.
Then click Location.
On this screen I use my "Markers" for the "Start" and "End" points.
Then select "GO"
Using the Markers are important, it will copy exactly where you tell it too. So get your markers tight and right.
I hope this helps.
Steven
Utility.
Track.
Then select "ALL".
Then select "GO"
Utility.
Track.
Then select "GO"
I hope this helps.
Steven
