metalhead28
Hates Raymond
killthepixel said:And you must also hear this Impaled song: "Rest in faeces"
Yeah, I am an Impaled fan, I've heard that song.
Ross Sewage nearly burned my hair off spitting fire a little too low at a show one time.
metalhead28 said:Hey dude. Yeah, the V-AMP I used is the rack mount version. I believe I paid $169. So don't kill your mother, just buy one, haha![]()
metalhead28 said:For that song, I used my Jackson soloist with a Seymour Duncan full shred pickup (not super high output), tuned down to B, plugged into the V-amp, into my M-Audio sound card, into Sonar. That's it. I used the digital output from the V-Amp, but I think the analog out is just as good.:
metalhead28 said:I've got my settings saved on the V-amp so I'll check those out when I'm at home and post em for you. I know it was the "modern high gain" model and I played around with cabinet settings to get that sound.
All I did to it in my software was put a doubler plug in on it. I only did that becasue I didn't record stereo tracks. That is just one track. If I recorded two tracks I wouldn't have used any plugs. I think I did EQ out a little 500Hz. I'll check. (I just listened to it again....I'm positive I eq'd out a bunch at 500Hz. I'll let you know.)
metalhead28 said:The fast blasts are 1/8 notes on the kick and snare simultaneously at 300 bpm. I think there are a couple short sections where I double timed the kicks to 1/16 notes.
I kept the snare velocity pretty low during the fast blast sections to try and make it sound a little more realistic. I was imagining Flo Mounier while I was doing those parts. Ever seen his 300+ blast beats? Amazing.
metalhead28 said:Okay, the V-amp settings:
Amp model: "Modern High Gain"
Cabinet Model: #14
Gain: 5 o'clock
Volume: 2 or 3 o'clock (just to get a good recording level)
Bass: 1 o'clock
Mid: 3 o'clock
Treble: o'clock
Reverb: 8 o'clock (just barely on, probably doesn't make any difference)
No effects
In my software a did an cut at 500 hz, about -6 db.
If you double track with the V-Amp it helps alot to use different cabinet models. Actually I wouldn't change anything but the cabinet model becasue that has a huge impact on the tone. With those settings, cabinet numbers 9,10,14,15 all sound pretty cool but alot different.
Bloodsoaked said:Thanks so much dude!!! I copied all the info and once I get the V-Amp I will let you know how it works out.
If you were going to recored using the v-amp and a real miced amp, would you use two tracks of the v-amp panned left and two tracks of the miced amp panned right? I think that might just add something to the song/mix. Any opinions?
I live in an apartment and it is getting harder and harder to mic my amp for recording and thought the v-amp would solve allot of those problems and since the sound you got on this song is from the v-amp I am thinking I might be able to use the v-amp 100% for recording my guitars. If you were to use the v-amp 100% for the guitars would you just change the cabinet model for the 3-4 guitar tracks or use the same cabinet for all the tracks?
Peter
metalhead28 said:First of all I would put the same thing on both sides of the stereo field. So if I recorded 2 tracks with one sound on the V-Amp I would pan them one left and one right.
If I was using just the V-Amp, I would probably record 2 tracks as mentioned, and then change the cabinet model and record two more tracks and pan them left and right as well. I would never want an unbalanced guitar sound from right to left.
I'd record at least 4 tracks. Maybe 6. You might even try recording 2 of the tracks with alot less gain for clarity's sake.
(I edited my last post becasue I left off the "treble" setting)
Bloodsoaked said:Cool...I got the treble setting saved now as well.
Right niw when I record my guitar tracks I have 2 paned left and 2 paned right with them all sounding the same from my Marshall amp. Just so I am sure, if I was to use the v-amp you would do the following:
2 tracks with say cabinet 1, 1 paned left, 1 paned right
2 tracks with say cabinet 2, 1 paned left, 1 paned right
That would give an even sound when recorded, is that what your talking about?
WHat you mentioned the unbalanced guitar sound from right to left...what about in a "real" band situation? 2 guitar players with two different sounds, how would these be recorded so not to get an unbalanced sound?
Peter
metalhead28 said:Your description is pretty much exactly what I would do. As far as considering the "real band" thing. If I recorded 2 guitar players I would probably record them through the same rig anyway unless they wanted otherwise. I guess a little difference from left to right might not be a bad thing, but I wouldn't want a totally different sound. Especially if the guitars are playing the same thing. If the guitars were playing very different lines then a different sound might work pretty well. That doesn't happen too often in metal. Even with harmonised parts, I would want the same tone on either side.
Cabinet Model: #14
Gain: 5 o'clock
Bass: 1 o'clock
Mid: 3 o'clock
Treble: 3 o'clock
No effects
