Hooking up two M-308 mixers?
  • Thread starter Thread starter Bigsnake00
B
Bigsnake00
Is this possible, How would I go about doing it? I am recording to a Tascam 38.
Thanks
Hooking up two M300 series mixers is accomplished by taking the main outs of all the busses, axillary, effects and solo outputs and putting them into the SUB inputs on the second mixer.
Once this is done, the two boards will act as one mixer.
The only trick part of the connection is tying the two solo systems together because of the signal and the control signal connection to mute all channels on both boards when any channel is soloed.
Here's a diagram from the manual for that;
Cheers! :)
So how many extra cords would that be.....? Sounds Like alot....
Well, let's do some math, shall we?
- 4 busses outs...= 4 cables; RCA to RCA
- 2 stereo outs....= 2 cables; RCA to RCA
- 2 aux outs...... = 2 cables; RCA to RCA
- 1 effect out ... = 1 cable; RCA to RCA
- 1 TRS insert cable for the solo system special cascade connection with 1/4" TS plugs at the other end
- 1 1/4 inch female to RCA male adapter
All together equals 10 cables and adaptor...probably about 30 - 40 bucks for decent 3 ft length wires at a musical instrument shop.
Cheers! :)
