B
Bob's Mods
Mixing in the box more the issue???? Maybe????
This thread really turned into a tape vs digital thing a ways back. After some thought on the subject, whether its tape or digital, this is only the medium that the sound is glued to. Its just media...plain and simple. The early problems of digital appear to have been largely worked out. Tape seems to have some sonic character to it as oppossed to digital which is uncolored. I believe that its not about the medium but more about the room, the mics, the engineers skill and very importantly the musical skill of artist being recorded. All this was stated earlier. Gear does play a role but not as big a role as I thought. After hearing many good mixes that were recorded in the digital domain...I believe the tape vs digital thing is a complete non issue. If you like the character of tape thats fine but its out of the rhelm of reality for the typical home wrecker. If you or your band is musical, you got a good engineer, a decent room and some decent mics...the groove should end up on the media.
The issue I suspect that is bigger than a tape vs digital thing is mixing in the box vs out of the box (analog mixing). After some experience with recording and yes..some mods to my gear...I'm getting very musical sounding mixes. The issue I face is when it comes to mix time. I have always had a tough time getting mixing in the box to give each track its own sense of space. I have learned how to massage that problem reasonably well however. One trick is to keep the track count low. There are others. Sonic A states he prefers the sound of mixing out of the box and he's one of the top pros on this site. If its good enough for him then its good enough for me. If you haven't read his bio yet you should. My early problem with flat sounding mixes may more have been related to inexperience, a lousy room and mixing in the box. There were some other threads relating to mixing in the box that were very good. Again though, mixing out of the box using an analog console can be very costly and most likely be impractical for the typical home wrecker with limited funds and time and freedom of space to record. I have found that the free plug in UpStereo to be a God send for giving your mixes some width. Like all things you have to be careful with it, know how to use it correctly and not over do it.
Bob Mod
Bob Mod
