LOL As I never disagree with you Shailat, this is a first, and only on a couple of small points in your post. However, it includes everything I have been working on over the last couple of years.
Quote;
"Mixing in a computer hasnt yet reaches the sonic quality of a good analog consule".
That is absolutely no longer the case. As far as pure audio is concerned, it is now able to surpass anything previously possible in analogue only, including extended frequency range and dynamics.
Obviously it depends on the limitations of the equipment used, but it is clearly possible to produce top quality audio even at 24/48, providing great case is taken with the conversions, and keeping the system jitter free.
You are not going to get that quality with using a soundcard, you need dedicated specialist equipment, but all-in-all it is realistic and relatively cheap.
Logistically an analogue console always had limitations, as has recording on magnetic media. Digital technology has now surpassed these limitations.
Quote:
"I disagree about the difference between 44.1 - 48.1 and even between 44.1 to 96. On several blind tests people have not been able to tell the difference. If you have to resample then the difference is useless or worse".
(note - I don't understand the last line)
I have seen the result of a number of these tests. Very strange, until you ascertain what equipment and configuration they used to "test". For a start playing a compressed medium mastered to 44.1 / 16 will very obviously not demonstrate the advantages of a 24 / 48 or higher quality recording (!?)
I can assure you one thing, the difference between 44.1 and 48 is destinct and very audible. The difference between 48 and 96 is also very clear, the difference between 96 and 192 is more difficult to hear, but it is there without any question and becomes more and more apparent when you start building tracks. Needless to say the difference between 44.1 and 96 or 192 is huge.
I have yet to encounter one single person, trained ears or not, whom I have played things to at different rates who have not heard an immediate difference.
Until a couple of years ago the comments "digital isn't as good" were valid. Today, they are obsolete. Very often these comments are made by people accustomed to working in the analogue domain, in which case they should re-phrase their comments to "my ears are accustomed to pleasant harmonic distortion"
