Home recording start-up
  • Thread starter Thread starter easton15
E
easton15
I have a new PC and the following equipment:
Fender Strat (american)
Boss ME-50 Effects Pedal
Boss DR-660 Pad
Kaoss 2
Yahmaha MG10/2 Mixer
I want to start recording and mastering on my comp. I have $1200 to play with. What should I have as far as hardware and software.
How many others are involved in recording? How many tracks do you need to record at one time?
There are basically 3 options:
1. All PC based approach
2. Standalone digital recorder
3. Hybrid
Beyond the recorder, you will need some mics and other misc gear. Do you already have a reasonable good PC?
Ed
Welcome to the BB Easton. As mentioned by Ed, there are several ways to go when it comes to recording systems, I'll assume you want to use your computer. To get started get a couple of good mic's ( Shure ) is a good brand, but there are many others. get at least one "Dynamic" ( good for vocals ) and one "Condenser " mic ( good for Instruments). You'll need some recording software. I recomend "Sonar", but again there are many other good programs. ( even some very inexpesive programs available online ( like N-Track Studio ). Install the recording software on your computer, Plug your mixer into your computer, plug your mic's into your mixer, and ba bing ba boom your there. This is a very basic set up, which will cost you much less then 1200$. But not to worry once you get going you'll spend your money on up grading all of the above items. There are many experts ( I'm not one ) here on this BB that will be happy to help you with any problems or questions that come up ( and they will). Good Luck.
I do have a good PC. 2.8GHz P4, 512MB, 120GB. I do plan on recording multipul instruments at once, but for the most part it will just be me recording a piece at a time.
Apart from the suggestions above, and regardless of what software/sequencer you end up using, you should definitely consider a second, fast hard drive for your audio data.
This will make a HUGE difference, as otherwise your one lonely hard drive will have a heck of a time keeping up running the program, reading audio, plug-ins, etc. all at the same time.
this question is so open on what to get, it is impossible to answer.
mics, software, cables, acoustic treatment.
I'm looking at getting the E-mu 1820m, dbx 266xl compressor and bbe 482i sonic maximizer. Should I get any other equipment? are these good items?
The card is nice, but how about an M-Audio 1010LT instead? It'll save you $220, and since you will mostly be recording things one at a time anyway, even this will be overkill. But, to each his own.
I say screw the outboard compressors and other gear. Spend your money on a good sequencing software, preferrably Sonar 3, and it's not just me, and use software-based DXI and VSTI compressors, maximizers, limiters, EQ's etc. etc. etc. For the $220 I saved you on your soundcard, you can almost get Sonar3 Producer off of Ebay new.
Next, I'd decide exactly how you are going to record. Does your footpedals allow you to record direct, or are you going to mic your amp? If you are going to mic your amp, get yourself a Shure SM57. This mic is good for basically anything. It's not the BEST at everything, but it will do. There is a different mic DistortedRumble mentioned in a different thread when he gives his low-cost "pro" setup. You could go with that too.
Now that you have a soundcard, a mic, and great software, it's just about time to record, and I bet you have PLENTY of cash left over from the original $1200. I would suspect you are planning on mixing the songs at home. If that is the case, monitors would be the next thing I purchase. You can't mix it if you can't hear it. Yorkville YSM1p's or M-Audio BX-8's are about the lowest I would go pricewise.
So, that just might eat up your $1200. Any cash left over, I would put towards a good condenser mic. You don't want ALL of your vocals recorded on the 57 do you? Maybe you do. It works great for a lot of folks, but a good(price performance) condenser would be my next purchase.
As I see it, your whole budget will be driven by what you get Sonar for off of Ebay, ""or elsewhere"":o :confused: if you choose to go that route.
The last thing I would get is room treatment. Not that it's last in importance, because it is important in order to mix properly, but playing/singing/recording is just more fun.:D
Thanks for the help Ibrow! I really needed some pointers on this. I plan on desinating a PC to just recording, so hopefully this all works out.
pennylink said:
....you should definitely consider a second, fast hard drive for your audio data....
And some more RAM. You already have 512mb. You should consider getting 512 more megabytes.
