Mick Doobie
Maderator
I'm using a Boss DR-670 to record "drum" tracks. I'm recording each drum on a separate track, muting all other drums inside the Boss to get the one drum for each track. I'm running a midi cable between the two, my Tascam 2488 as the master, and the Boss being the slave. I'm getting a hiss on the recorded track(s), progressively worse and compounded with each additional track.
It doesn't seem like in the past I have had quite as much problems with hiss. It doesn't seem to matter if when setting levels I cut back on the trim and crank the volume on the Boss(about 3/4 up), or crank the trim and ease up on the Boss volume.
Any advice on solving or minimizing the problem? Is there a proper method of setting the levels(Drum machine vs trim) in the signal chain to minimize(or get rid of) the hiss?
The final product is useless unless I can do something about the problem. Sounds like doo doo.
Thanks
Thanks
